Switch Ignition Magneto Keyed 111215 replaced by 103991 List.jpg 1.0.0
8 Screenshots
1 page 176KB  from Demystification Guide #492-4509
Switch rotated to place start terminal at the top
1 page 155KB
111215 ignition switch replaced by 103991
5-terminal 3-position ignition switch for magneto ignition.  There may be a 6th terminal to ground the body of the switch. Early switches had 5 terminals and most likely the reason for the part number change.
Tractor Switch Ignition Magneto ignition with electric start 103991 ($39.12 May 22, 2020)
(Threads 5/8"-32) 6-terminal 3-position
Used 1974-1985 and 1987
Replaces 111215 5-terminal 3-position
Tractor Switch Ignition Magneto ignition with electric start 111215
(Threads 5/8"-32) 5-terminal 3-position used 1985-1993
111215 5-terminal 3-position replaced by 103991
Napa and Prime-Line replacement switch 7-01893 (9/16" mounting stem)
Stens replacement switch 430-128 (9/16" mounting stem)
Rotary replacement switch 31-7280 (9/16" mounting stem)
Napa and Prime-Line 5-terminal connector body that uses Packard female spade terminals 7-016034 (With terminals and wire leads 7-01910)
Stens 5-terminal connector body that uses Packard female spade terminals 430-206 (With terminals and wire leads 430-223)
Rotary 5-terminal connector body with terminals and wire leads 31-6662
Bare 5-wire female plastic connector is Kohler 48 155 01 (This also used on the Kohler engine to tractor connector.) Tractor harness male connector is Toro 112185 and illustrated with the low oil switch.
103991 Magneto ignition switch used on
1974 models 1-0280*, 1 - 0285, 1 -0353, 1 -0354, 1 -0356, 1 -0380, 1-0385*, 1 -0390, 1 -0480, 1 -04851 -0490, 1-0495*, 1 -0510, 2-4300*  *****
1975 models 1-0281* for ES, 1-0282* for ES, 1 -0286, 1 -0287* for RS, 1-0357*, 1-0375*, 3-0114*  *****
1976 models 62-08BP01*, 62-10BP01*  *****
1977 models 72-08BP01*, 72-10BP01*  *****
1978 models 82-08BP01*, 82-11BP01*  *****
1979 models 92-08BF01*, 92-11BF01*, 92-11BP01*, 93 -05BP01, 93 -05BP02, 93-08BP01*, 93-08BP02*, 93 -08XP02, 93-11BP01* *****
1980 models 03 -05BP01, 03-08BP01*, 03 -08EP01, 03 -08XP01, 03-11BP01*  *****
1981 models 03 -05BP02, 03-08BP02*, 03 -08EP01, 03-11BP02*  *****
1982 models 02-08BX01*, 02-11BE01*, 02-11BP05*, 02-16BE01*, 02-16BP04*, 03 -08EP01, 23 -05BP01, 23-08BP01* for ES, 23-11BP01* for ES, 23-11BX01* for ES, A1-114201*, A1-164201*, A1-184801*, A2-083201*, A2-103201*, A2-113701*, A2-163701*, A2-164201*, A3 -053201, A3-083201* for ES  *****
1983 models 03-08BP03*, 03 -08EP01, 12-11BE01*, 12-11BP01*, 12-16BE01*, 12-16BP01*, 23-08BP02*, 23-08BX01*, 23-08XP01*, 23-11BP02*, A1-114202*, A1-164202*, A2-083202*, D1-184801*, D2-113601*, D2-113701*, D2-163701*  *****
1984 models 12-11BP02*, 12-16BE02*, 23-08BP03*, 23-11BP03*, A1-11B801*, A1-16B801*, A1-18BE01*, A2-11BP01*, A2-11BX01*, A2-16BP01*, B2-11BX91*  *****
1985 models 22-08B301*, 22-11B301*, 22-11B501*, 22-11BE01*, 22-16B501*, 33-08B301* for ES, 33-08B501* for ES, 33-08BP01* for ES, 33 -08X301, 33-11B501* for ES, 33-11BP01*, B2-11B301*, B2-16B301* (Conversion Kit 110973 for 33-08BP01 & 33-11BP01)  *****
1987 models B2-11B591*, B2-16B591*  *****
111215 Magneto ignition switch used on
1985 model B3-08B302* for ES  ***** - All available info lists this as a 1981 model - Could be 1985 or 1986 model
1986 models 21-08K801*, 21-08K802*, 21 -10K802, 21 -10K803, 21 -12K802, 21 -12K803, 21 -12KE01, 21 -12KE02, 22-08B302*, 22-11B302*, 22-11B502*, 22-12TE01*, 31 -14K801, 31 -16K802, 31 -17K802, 31 -17KE02, 31-20KE01*, 33-08B303* for ES, 33-08B502* for ES, 33-08X303* for ES, 33-11B502* for ES, B3-08B303* for ES, B3-11B502* for ES  *****
1987 models 21-08K803*, 21-10K804*, 21-12K804*, 21-12KE03*, 31-14K802*, 31-16K803*, 31-18K801*, 31-18KE01*, 32-08B501*, 32-11B301*, 32-11B401*, 32-11B501*, 32-11BX01*, 32-12K601*, 33-08B304*, 33-08B401*, 33-08B503*, 33-11B503*, 33-11B601*, 41-18KE01*, B2-11B392*, B3-08B391*, B3-11B591*, C3-12K501*  *****
1988 models 21-08K804*, 21-10K805*, 21-12K805*, 22-13KE01*, 22-17KE01*, 31-14K803*, 31-16K804*, 32-08B402*, 32-11B402*, 32-11BX02*, 32-12K602*, 33-08B402*, 33-08B504*, 33-11B602*, B1 -16O801, C3-12K502*, E1-12K801*, E2-09K401*, E2-12K501*, E2-13K501*, E2-17K501*, F2-09K401*, F2-12K501*  *****
1989 models 21-10K806*, 21-12K806*, 22-13KE02*, 22-17KE02*, 31-14K804*, 31 -16O801, 32-11B403*, 32-12B501*, 32-12BE01*, 42-08B401*, 42-11B501*, B1 -16O802
E1-12K802*, E2-12K502*, E2-12KE01*, E2-17K502*, E3-10B401*, E3-12K602*, R2-12K501*, R2-12KE01*, S2-12K501*  *****
1990 models 31-10K801*, 31-12K801*, 31-12KE01*, 31 -16O802, 32-10B501*, 32-10BE01*, 32-12O501*, 32-12OE01*, 41 -16OE01, R1-12K801*, R1-12K802*, R1 -16O801, R1 -16O802, R2-17K501*, R2-17K502*, R3-10B401*, R3-12B601*, R3-12K601*  *****
1991 models 31-10K802*, 31-12K802*, 31 -16O803, 32-12O5A1*, 32-12OEA1*, 32-12B5A2*, 32-12BEA2*, 51-12KE01*, 51 -16OE01, A2-12K501*, A2-12KE02*, R3-10B402*  *****
1992 models R3-10B404*, R3-12B602*  *****
1993 model R3-10B404*  *****
