Switch Ignition 101917 replaced by 92-6785 .jpg 1.0.0
5 Screenshots
2 pages from Demystification Guide #492-4761
How to troubleshoot
101917 switch replaced by 92-6785
5-terminal 4-position key switch
This switch requires a starter solenoid
Tractor Switch Ignition Battery ignition with electric start 101917
(Threads 5/8"-32) 5-terminal 4-position used 1972-1974
(PSB #134?) List with 1970 1-8755 Lawn Ranger at Toro but D-Series mix-up
101917 5-terminal 4-position replaced by 92-6785
Tractor Switch Ignition Battery ignition with electric start 92-6785
(Threads ? Retained by 700919 nut) 5-terminal 4-position used 1994-2007
Replaces 101917 5-terminal 4-position
92-6785 5-terminal 4-position available 06/08 $31.47 from RCPW
Also used on magneto ignition to control a kill relay.
Switch 101917 used on
1972 Bronco 14 model 1-0422
1972 Bronco 14 model 1-0423
1972 Charger 10 model 1-0410
1972 Charger 12 model 1-0401
1972 Commando 800 4-Speed model 1-0110
1972 Raider 8 model 1-0330
1972 Raider 10 model 1-0301
1972 Raider 12 model 1-0311 (This model also made in Belgium)
1972 Raider 14 model 1-0320
1973 8hp 4-Speed model 1-0120 - Horizontal shaft (Also made in Belgium as Commando 800)
1973 8hp 4-Speed model 1-0130 - Horizontal shaft - Commando 800?
1973 8hp 8-Speed model 1-0370 - Horizontal shaft
1973 10hp 8-Speed model 1-0360 ??????????????
1973 10hp 8-Speed model 1-0365
1973 12hp 8-Speed model 1-0350 ??????????
1973 12hp 8-Speed model 1-0353 - Listed in PSB #301E for 1973-74. Suspect 1973 is wrong ?????????
1973 12hp 8-Speed model 1-0354 - Listed in PSB #301E for 1973-74. Suspect 1973 is wrong ?????????
1973 12hp 8-Speed model 1-0355 - One made in Belgium and located in Wales
1973 14hp 8-Speed model 1-0340
1973 18hp Automatic model 1-0600
1973 18hp Automatic model 1-0601
1973 18hp Automatic model 1-0610
1973 18hp Automatic model 1-0620
1973 Raider 10 8-Speed model 1-0360 - Made in Belgium
1973 Raider 12 8-Speed model 1-0350 - Made in Belgium
1974 Raider 10 4-Speed model 1-0393 ????????????????? - May not be correct
Switch 92-6785 used on
72042, 264-6 Yard Tractor, 1994 (SN 4900001-4999999)
72043, 264-H Yard Tractor, 1994 (SN 4900001-4999999)
72062, 264-6 Yard Tractor, 1994 (SN 4900001-4999999)
72063, 264-H Yard Tractor, 1994 (SN 4900001-4999999)
72083, 266-H Yard Tractor, 1994 (SN 4900001-4999999)
72103, 268-H Yard Tractor, 1994 (SN 4900001-4999999)
72042, 264-6 Yard Tractor, 1995 (SN 5900001-5900796)
72042, 264-6 Yard Tractor, 1995 (SN 5900797-5999999)
72043, 264-H Yard Tractor, 1995 (SN 5900001-5901475)
72043, 264-H Yard Tractor, 1995 (SN 5901476-5999999)
72062, 264-6 Yard Tractor, 1995 (SN 5900001-5900227)
72062, 264-6 Yard Tractor, 1995 (SN 5900228-5999999)
72063, 264-H Yard Tractor, 1995 (SN 5900001-5900498)
72063, 264-H Yard Tractor, 1995 (SN 5900499-5999999)
72084, 266-H Yard Tractor, 1995 (SN 5900001-5999999)
72103, 268-H Yard Tractor, 1995 (SN 5900001-5900600)
72103, 268-H Yard Tractor, 1995 (SN 5900601-5999999)
