Engine Kohler Magnum M 8 M10 M12 M14 M16 OM.pdf
Operator manual #TP-2200-A
8 pages 6158KB
Includes M10
Operator manual #TP-2200-F (Don't know why the 10hp is not included unless it was no longer produced at the time of printing)
16 pages 492.07KB
Dated 7/85 Revised 12/01
M8 (8hp or 6KW)
1986 308-8 model 21-08K801 - Using M8S-301511
1986 308-8 model 21-08K802 - Using M8S-301511
1987 308-8 model 21-08K803 - Using M8S-301511
1988 308-8 model 21-08K804 - Using M8S-301511
The following were supplied to Wheel Horse according to Kohler records
M8-301511 - 1986, 1987, 1988
M10 (10hp or 7.5KW)
1987 310-8 model 21-10K804 - Using M10S-461521
1988 310-8 model 21-10K805 - Using M10S-461521
1989 310-8 model 21-10K806 - Using M10S-461533 - (M10S-461521 at Toro)
1990 310-8 model 31-10K801 - Using M10S-461533 - (M10S-461521 at Toro)
1991 310-8 model 31-10K802 - Using M10S-461533 - (M10S-461521 at Toro)
1992 310-8 model 31-10K803 - Using M10S-461545 - (M10S-46154 at Toro is wrong)
1993 310-8 model 73320 - Using M10S-461545 - (M10S-46145 at Toro is wrong)
M10-461521 - 1987, 1988, 1989, 1990, 1991
M10-461533 - One found with 1989 Kohler build date and maroon hood decal.
M10-461545 - 1992, 1993, ?
M12 (12hp or 9KW)
1987 312-8 model 21-12K804 - Using M12S-471527
1987 312-A model 21-12KE03 - Using M12S-471527
1988 312-8 model 21-12K805 - Using M12S-471527
1988 312-8e model E1-12K801 - Using M12S-471546
1989 312-8 model 21-12K806 - Using M12S-471527
1989 312-8e model E1-12K802 - Using M12S-471546
1990 312-8 model 31-12K801 - Using M12S-471527
1990 312-8e model R1-12K801 - Using M12S-471546
1990 312-8e model R1-12K802 - Using M12S-471527
1990 312-H model 31-12KE01 - Using M12S-471527
1991 312-8 model 31-12K802 Serial 1000001-1999999 - Using M12S-471527
1991 312-8e model R1-12K803 Serial 1000001-1999999 - Using M12S-471527 - A guess
1991 312-H model 51-12KE01 Serial 1000001-1999999 - Using M12S-471527 (M12S-471521 wrong at Toro)
1992 312-8 model 31-12K804 Serial 2000001-2999999 - Using M12S-471527
1992 312-8e model R1-12K804 Serial 2000001-2999999 - Using M12S-471527
1992 312-H model 51-12KE02 Serial 2000001-2999999 - Using M12S-471527 (M12S-471521 wrong at Toro)
1993 312-8e model 73380 Serial 3900001-3999999 - Using M12S-471527
1994 312-8 model 73362 Serial 4900001-4999999 - Using M12S-471527
1994 312-8e model 73380 Serial 4900001-4999999 - Using M12S-471527
1995 312-8 model 73362 Serial 5900001-5999999 - Using M12S-471527
1996 312-8 model 73362 Serial 6900001-6999999 - Using M12S-471527
1996 312-8 model 73363 Serial 6900001-6999999 - Using M12S-471527
1997 312-8 model 73363 Serial 7900001-7999999 - Using M12S-471527
M12-471527 - 1987, 1988, 1989, 1990, 1991, 1992, 1993, 1994, 1995, 1996, 1997
M12-471546 - 1988, 1989, 1990
M14 (14hp or 10.5KW)
1987 414-8 model 31-14K802 - Uses M14S-601524
1988 414-8 model 31-14K803 - Uses M14S-601540
1989 414-8 model 31-14K804 - Uses M14S-601540
1993-1996 314-8 model 73400 - Uses M14S-601559
1993-1996 314-H model 73401 - Uses M14S-601559
1996-1997 314-8 model 73402 - Uses M14S-601559
1996-1997 314-H model 73403 - Uses M14S-601559
M14-601524 - 1987
M14-601540 - 1988, 1989,
M14-601559 - 1993, 1994, 1995, 1996, 1997
M16 (16hp or 11.9KW)
1987 416-8 model 31-16K803 - Uses M16S-711523
1988 416-8 model 31-16K804 - Uses M16S-711523
M16-711523 - 1987, 1988
