Model 110995
8 one-piece pinion differential
Single axle seal
4 pages 189.80KB
Used 1985-1993
1985 416-8 model 31-16K801
1985 417-8 model 31-17K801
1986 414-8 model 31-14K801
1986 416-8 model 31-16K802
1986 417-8 model 31-17K802
1987 414-8 model 31-14K802
1987 416-8 model 31-16K803
1987 418-8 model 31-18K801
1988 414-8 model 31-14K803
1988 416-8 model 31-16K804
1989 414-8 model 31-14K804
1989 416-8 model 31-16O801
1990 312-8 model 31-12K801 - Toro lists this model as using the 110996 with 1" axle 4-pinion differential which is wrong
1990 312-8e model R1-12K802 - Exported model
1990 316-8e models R1-16O801 and R1-16O802 - Exported models
1990 416-8 model 31-16O802
1990 520-8 model 41-20O801
1991 310-8 model 31-10K802 - (Serial numbers 11752, 11753, 11754 and 11755 used the 110995 transmission with 8 pinions and 1-1/8" axles) Perhaps this should be for the 1990 310-8
1991 312-8 model 31-12K802 Serial 1900001-1999999
1991 416-8 model 31-16O803 Serial 1900001-1999999
1992 312-8 model 31-12K804 Serial 2900001-2999999
1992 312-8e model R1-12K804 Serial 2900001-2999999 - Exported model
1992 316-8e model R1-16O804 Serial 2900001-2999999 - Exported model
1992 416-8 model 31-16O804 Serial 2900001-2999999
Toro lists the following as using 92-8708 transmission with 8 pinions and double axle seals but the parts lists have 110995 with 8 pinions and a single axle seal.
1993 314-8 model 73400 Serial 3900001-3999999
1993 416-8 model 73420 Serial 3900001-3999999
1993 416-8e model 73440 Serial 3900001-3999999 - Exported model
