Transmission Gear Uni-drive 8-speed 1.125in axle 10-pinion LS 5073 1970-1973 IPL.pdf
Model 5073
2 pages 522.62KB
1-1/8" axles Uses 7202 replaced by 121384 12" right axle and 7203 11-1/4" left axle and 937022 Woodruff #15 keys - 1/4" x 1") [937002 replaced by 937022 - May be a typo]
Axle 101511 also shows as being replaced by 121384
10-pinion limited slip differential eight-speed
Has a dipstick
5073 used in
1970 Raider 10 model 1-6051
1970 Raider 12 model 1-6251
1970 Raider 12 model 1-6252
1970 Raider 12 model 1-6253
1971 Raider 10 model 1-0300
1971 Raider 12 model 1-0310
1972 Raider 12 model 1-0311
1972 Raider 14 model 1-0320
1973 14hp 8-speed model 1-0340
1973 12hp 8-speed model 1-0350
1973 Raider 12 8-speed model 1-0350 - Export model
