Transmission Gear Uni-drive 6-speed 1.125in axle 10-pinion LS 5071 1969 IPL.pdf
Model 5071
2 pages 123.73KB
1-1/8" axles Uses 7202 replaced by 121384 12" right axle and 7203 11-1/4" left axle and 937022 Woodruff #15 keys - 1/4" x 1") [937002 replaced by 937022 - May be a typo]
Axle 101511 also shows as being replaced by 121384
10 pinion limited slip differential six-speed
5071 replaced by 5073 in 1970
6-speeds have the brake drum mounted on the 11/44 (mushroom) gear. Use Section III of the service manual.
Aluminum side plates on the 5060 differential...steel side plates on the 5071
5071 used in
1969 Raider 10 model 1-6041
1969 Raider 12 model 1-6241
