Transmission Gear Uni-drive 3-speed 1.125in axle 2-pinion 5059 1966 IPL.pdf
Model 5059
2 beveled pinion gear differential three-speed
(This may be the 5047 ipl with the only difference being 1965-up models used the new shift rails)
4 pages 644.53KB
3-speeds have the brake drum mounted on the 11/44 (mushroom) gear. Use Section II of the service manual.
This parts list shows the 933168 roll pin for the shifter donut 5/32" x 13/16"
Replaced by 32121-114 spirol pin
Model 5059 replaced 5045, 5047 and 5051
Model 5059 may have only been available from parts for complete replacement
5059 transmission fits the tractor models 953, 1054 and 1054A
