Transmission Gear Uni-drive 3-speed 1.125in axle 2-pinion 5051 1965 IPL.pdf
Model 5051
2 beveled pinion gear differential three-speed
(This may be the 5047 ipl with the only difference being 1965 models used the new shift rails)
4 pages 644.53KB
3-speeds have the brake drum mounted on the 11/44 (mushroom) gear. Use Section II of the service manual.
This parts list shows the 933168 roll pin for the shifter donut 5/32" x 13/16"
Replaced by 32121-114 spirol pin
New shift rails in 1965
Model 5051 replaces 5045 and 5047
Model 5051 replaced by 5059 for 1966
5051 transmission used in
1965 model 1054A
