Transmission Gear Uni-drive 3-speed 1.000in axle 4-pinion 5046 1964 IPL.pdf
Model 5046
1" axles 2 of 3904 10-5/8" long
4 two-piece pinion differential three-speed
1 page 149.03KB
3-speeds have the brake drum mounted on the 11/44 (mushroom) gear. Use Section II of the service manual.
This parts list shows the 933168 roll pin for the shifter donut 5/32" x 13/16"
Replaced by 32121-114 spirol pin
Model 5046 same as 5025 except for the shifter
Model 5046 replaced by 5049 for 1965 and 5053 for 1966-1969
Model 5046 transmission used in
1964 model 34E
1964 model 34R
1964 model 604
1964 model 654
1964 model 704
