Tractor 1973 Auto 10hp 12hp 14hp 16hp Automatic OM Wiring SN.pdf
4 Screenshots
Operator manual #A-5325
8 pages 2.42MB
Dated 7/72
Note - Electric clutch fuse #101639 is a SFE-20 amp
1973 10hp Auto model 1-0470 Uses 1" axles and 4-pinion differential in 5087 transaxle with 7880 Hydrogear
1973 10hp Auto model 1-0475 Uses 1" axles and 4-pinion differential in 5090 transaxle with 102866 Piston-piston Hydrogear
1973 12hp Auto model 1-0460 Uses 1-1/8" axles and 10-pinion limited slip differential in 5062 transaxle with 7880 Hydrogear
1973 12hp Auto model 1-0465 Uses 1-1/8" axles and 10-pinion limited slip differential in 5089 transaxle with 102866 Piston-piston Hydrogear
1973 14hp Auto model 1-0430 Uses 1-1/8" axles and 10-pinion limited slip differential in 5062 transaxle with 7880 Hydrogear
1973 14hp Auto model 1-0435 Uses 1-1/8" axles and 10-pinion limited slip differential in 5089 transaxle with 102866 Piston-piston Hydrogear
1973 serial numbers that have shown up for the 1-0435
0931348 - Model 1-0435-8
0936441 - Model 1-0435-8
0936438 - Model 1-0435-8
0936446 - Model 1-0435-8
1973 16hp Auto model 1-0440 Uses 1-1/8" axles and 8-pinion differential in 5088 transaxle with 102866 Piston-piston Hydrogear
